1 - 20 of 35 Posts
hi yesterday i ran out of petrol, Vauxhall Corsa Merit 'p' i today put fuel in (around halfway in the red) i go to start the engine and it ticks like an engine does when starting but doesnt catch and start up, what is the cure, could it be there is not enough fuel in there? or any other suggestion....
any help would be appreciated
Keep pumping for a while if I was you...sure you don't have a leak?
charge your battery, probably doesnt have enough to start car, Im guessing you ran out of petrol, tried starting car few times, and that killed batery, get some jump leads, and sure be good to go
A car tics over when its started. From what you are saying your car will not start?
im not good with cars haha.....you know when u trun the key...before it starts up it sorta tics or wateva it just does that, i know im probably not making sense but i dont know how to describe it :D
Yes mate, get your battery charged of get a bump start im sure car is fine.
Because your battery was already dead, just go try it mate..
i wonder if this has ever happened to mine... my car usually will only start if i rev it when starting it....
which is crap i had a new starter motor fitted 2 weeks after buying it cuz it just broke..:(
Thats why I said charge it, / get bump start, if battery dead chargin will sort, if starter motor is goosed, then bump start will be sorted
Which one?
Get in car, in forst or second gear, hold clutch down. get some people to push you in the car until you get decent speed 5/10mp and try starting the car
The 2nd coming
Get in car, put car in neutral, get some people to push you in the car until you get decent speed 5/10mp and try starting the car
fail.
put ignition to 2, get it moving as before, clutch down, 2nd gear, 10 or so mph.... pull the ****ing clutch up and give it some gas....
brace for juddery start, do not let the engine stall
1 - 20 of 35 Posts
