Status
Not open for further replies.
1 - 11 of 11 Posts
I have this Saab 9-3 turbo engine for sale, removed from a 2003 Corsa C SRi
You will get:
Engine, assembled
Inlet manifold
Throttle body
Tophat
Turbo
Downpipe
Clutch
Flywheel
Engine mounts
Wiring loom
ECU (stage 2 map)
The person who built the car apparently bought a Saab 9-3 turbo, drove it about for a while to ensure the engine was good and then got half way through doing this conversion before changing to another project. I therefore think there's n excellent chance the engine is a good one, but I haven't seen it running myself. Any inspection is welcome.
The price is £250. can put on a pallet if you would like to send a courier to collect.
these can and do make over 400bhp on stock internals. better than a c20let
(can't edit original post for some reason)
... So I have 100% everything to convert a C into a saab turbo including shafts if different, speedo with the original corsa C ecu etc if you know what I mean?
Basically sell all car without shell haha. Unless you want to sell the full car? Next project for me ..
I'm not the seller Iby but if you read the OP
You will get:
Engine, assembled
Inlet manifold
Throttle body
Tophat
Turbo
Downpipe
Clutch
Flywheel
Engine mounts
Wiring loom
ECU (stage 2 map)
I read somewhere that the corsa C needs two ECUS so I was making sure regarding this statement. One for dash etc and other for the engine and you had to run them side by size, its for the z20let conversion and was trying to make it clear if it needed two or one with this saab corsa C conversion.
1 - 11 of 11 Posts
Status
