I had this issue crop up over a month or two ago.. when doing over 30/40mph and braking relatively hard, there are a lot of vibrations through pedal, steering wheel, and pretty much rattles the whole car.
I thought it was a warped disc, so I replaced with new standard discs and pads.. and yes the drivers side was slightly warped.
Now the discs and pads have been on for over 400 miles and have bed in, but the symptoms are still happening. The brakes definately work though, and I just tried the brake vacuum test (press pedal 5 times and start engine) and the pedal did dip as it should.
Any ideas? Bleed lines?
