1.2 8v c12nz dizzy type lump, there is slight hesitation when setting of and a dip in the revs only just noticeable when first changing gears you have to touch the accelerator to give it 'push' . it does not cut out im being a little picky but my other 1.2 8v wasnt like this it has had a full service new CTS and everything else - have noticed the idle is also slightly rough as well its all pointing at a duff oxygen sensor from what i have read - it is nigh on 20 years old now but only done 68,000 miles ..
i just thought it may be worth asking for a second opinion ? possible lambda sensor on exhaust manifold at fault?
cheers
cheers
