Hope this is in the right place.
This is mainly a 'How do YOU do it? Is this right?' thread.
I soldered up a headunit ISO connector a few days ago as it had been crimped, badly.
My method is strip the cable, twist the wire, dip it in flux.
I have a soldering gun (it was cheap) with a wide/flat point, i melt a small pool of solder on that, and lay the wire in that and move up and down to cover.
Do that on both wires, then put a little more solder on the iron, put both wires together, and lay in the solder. Once the solder melts, gently lift them out. And let cool. Then heatshrink to protect.
I will be doing a few eyelets onto some thocker cable, so planned to flux and tin wire, then open up the eyelet crimp, flux, the. Push wire in and gently squeeze to hold its place. The. Heat and add solder. Will this work ok? Any other way/tips?
Cheers
Cheers
