Bought my first car ('08 Corsa 1.3) just over a month ago and a couple weeks back the speedometer stopped working properly. Initially, the needle was stuck at 20 mph even when I turned the car off. Then, when I was doing around 30mph it would read as 60 mph and get stuck there and creep up more whenever I turned the car off and drove again.
The fuel gauge and rpm works fine as well as the cig lighter.
A mechanic had a look at it and took the whole instrument cluster out and fiddled around with it and put it back in and it all seemed fine but a few days later I drove over a pot hole and it started playing up again.
It seems like I have no choice but the replace the whole instrument cluster but I was told it was complicated and expensive process as its coded?
Has anyone had a similar experience and solved the issue without replacing it? Or does anyone know where I could get a new one put in and coded? Im based in Birmingham. And what would happen to my milage readings?
Thanks a lot
Thanks a lot
