you dont even need spring clamps if your putting lowing springs on here how to get springs off with out clamp s
after taking the wheel off and car is on axle stand put the jack under the wish bone jack it up till compress's the spring, then undo the retaining nut on top of the strut untill its off , now slowly let the jack down and the spring will decompress , undo the rest of the bolts remove strut job done , now to put lowing springs on you can compress them enough by hand , put spring on and the srut top , push down as you so the shock comes threw , you will need some one just to put the nut one while you do this, do up tight and rebuild , i do it like that all the time but i know what im doing, if your not confident , PLEASE dont do it springs can kill and use spring claps this only applies to lowering springs you will never get a standard spring to compress down enough you will need clamps for that ..
