Hi all my sons Corsa D 1.2 11 plate is making a cha cha chaff plasticky scraping sound when under load. It follows engine revs up and down, it's in the area of cylinder 1&2. I've attached a video. The fluid is wd40 sprayed in vain to stop squeaky belt or pulley.
Hi there is sounds like the inlet manifold gasket has gone, it doesn't sound like its running on 4 cylinders....you could squirt some water over it when running and see if you can detect and air leak...from Fred in Essex.
