1 - 6 of 6 Posts
rite, ive jus bought me sound system, got a vibe cbr active sub, n sum jbl components n sony speakers... i thort id run my 4 speakers off a 500w 4 channel amp and my sub off the built in amp... thing is wen i looked on the bk of my headunit i hav only 2 RCA jacks... does that mean i can only hav 1 or the otha or not?? or can i get an RCA lead with like 4 ends so i can plug 2 in the 4 channel and 2 in the sub??? or does thiis mean ive gotta get a new headunit??
thanks
Hmmm do you mean you have 1 set of RCA? as in one red one white, what you can do is buy Y-splitters which would divide up and give you another pair of RCA's, so you can have both you speakers and sub wired up.
does your four channel amp have an rca input an output some do if so you only need 1 set running from your head unit then or maybe your in built vibe amp may have an rca output as well if not like clutch said you can get y splitters for under 10 quid i hope this helps
yea i kinda no wot yas mean... well on the 4 channel theres 2 rcas, like 2 red and 2 white... but i shud b able 2 bridge them wit jus 2 jacks... n yea on the headunit its jus 1 red and 1 white
on your 4 channel amp if there is 4 rca sockets it should be to as imput an 2 aas out put post a pic up if this is the case you can run the rca leads from your amp to the other amp which will mean you only need 1 set from the back of the head unit
1 - 6 of 6 Posts
