Hi peeps just bought wife an s plate 1.0l 5dr as a car to learn in as only cost £100.
Seems I have a lot of oil leaking from oil pressure switch, is this common and does it matter if I get a replacement from CAS.
Also can you buy thermostat gaskets on their own ?
Yes - a lot of them leak. But the replacement switch is cheap enough.
The thermostat gasket - you ought to be able to get one from a main dealer. If you're stuck ring Autovaux 01924 376003. Or you can make one from gasket material.
Hi I got oil pressure switch from centrals. Fitted it then looked at old one and had washer. Pulled other one back out and no washer. Put old washer on. So my question is have I done the correct thing?
