1 - 13 of 13 Posts
hey, how easy is it to fit a tachometer to a corsa b?because mine doesnt has one and i would really like.easy for a novice??guides?
a tacho is a speedo, you mean a rev counter? just wires up to the ignition coil, or theres a green wire that runs behind your dash :)
cue more detailed explanations
i thought a speedo was a speedo, a rev count was a rev count and a tachomete was them things truck drivers have? like a bit of paper called tachograph or something, that goes into the tachomete, and it gets punched everytime you have your legally required "tacho break"
or have i been bull****ted to by james again matt? lol
anyway as matt said there might be a wire running behind the dash if not will have to wire it up but its not impossible
You don't need to take the full dash off, just the clocks. It's just a case of dismantling the clock surround and pulling it out. Look for all the screws around it. It's like a jigsaw, you will have to remove certain pieces before others become reachable.
Deathscythe will probably be able to tell you how to wire up a rev gauge. He's our walking haynes manual.
remove the cowling round the steering wheel, then the border round the clocks, then the clocks, its all star screws, theres a metal hook at the top of the clocks flick it up and the clocks will pop forward, unplug them and look at the multi plug if you have a solid green wire on the plug then its a straight swop over, i believe its pin 17 or 18 if not then take the footwell cover off and check at the ecu, if you have it at the ecu then its a case of running the wire up the dash and linking it up, other then that link it to take a pulse off he coil which is the more messy route but problem is most corsas came with coil packs
d
Corsa C's have a rev counter as standard
if i had a corsa b, i wouldnt really go into great lengths to get one
there only good at showing u when to change gears or ragging your car etc...
apart from that most of the time the needle idles just below 1000 revs when u are at a set of traffic lights
d
Hi guys, in need of a bit of help here. I got to the part of takin the steering colum bits off, and the black surrounding fascia of the clocks, but i cant seem to get the clocks out enough in order to detach the cables, i can lift it up and see the plug bit at the bottom, but i cant detach the speedo cable away from it, any ideas ?
Sorted, i dared my self and tugged on the speedo cable, i heard something snap and i soiled my self, turned out to be that the cable was being restricted in length due to it being tie wrapped onto another cable :confused: anybody else had this prob.
Fitted the clocks, the rev counter does not work, doesnt look like i have the green wire i was told to look out for. Enquired at the garage and have quoted me £40plus for them to fit a receiving end plug (block that ur clocks go into in the dash) and connect it to the ecu. :eek:
Any cheaper ways of doing it ? :eek:
Thanks in advance
1 - 13 of 13 Posts
