1 - 6 of 6 Posts
I've done the Paperclip test and after taking all the flashes and pauses downand referring back to the topbuzz website, it's giving the fault code 43:
43---------------Primary ignition (distributor systems)------------High voltage (This is the fault with the primary ignition)
Anybody know what this means?
Check the distributor hasnt got any water in it, quite common on corsas, also check condition and connection of the HT leads as well.
Water could be shorting it out giving the high voltage code, otherwise i wouldnt know :confused:
Discussion Starter #5
Where is the distributor? And are HT leads the spark plugs?
The Red bit on the end of the engine, with the little red circle round it. Yeh the HT leads are those that come off the Distributor onto the spark plugs.
1 - 6 of 6 Posts
