Hi there,
Following on from this thread http://www.allcorsa.co.uk/forums/showthread.php/adapting-corsa-tid-54644.html?p=766160 where I was inquiring about using a Corsa B TID in a Renault Trafic I purchased the TID, sensor and plug to connect them but I can get the temperature to display.
Here is the situation;
* Equipment being tested in workshop, not fitted to van
* Power connected as in AJ's wiring diagram but note that I am using the same live source for both the permanent and switched live of the TID
* Sensor connected as in AJ's wiring diagram
* No other connections connected such as data and so on (does it need these?)
* I have tested the resistance of the sensor and it changes up when cold in the freezer
* Error code 171 appears on the TID in test mode
Any ideas what I am doing wrong?
Many thanks.
Discussion Starter · #2 ·
Hi again,
Further to my to the post above I have now bought another sensor and I can't get it to provide a reading either.
Does anyone have any ideas why this might be? Only things I can think of is that the TID needs a data connection or there is an error with the TID itself. Or maybe error codes need to be cleared?
Any help appreciated.
