Yesterday driving my 1.0 litre corsa B it suddenly got really hard to change gear.
I checked the condition of the cable and that was fine and then I adjusted the cable length a bit (you got a threaded bar at the end of the cable)
The car was ok after i adjusted it, the trouble is the adjustment bar is almost at it's full length so I've not got much adjustment left. The gear change is not quite as good as before even though the pedal is higher than the brake pedal, I could adjust it a little more but then that would be at max adjustment
Is it worth just driving it or is this a warning that I got to bite the bullet and get the clutch changed
