I took the front wheels off today to change discs and pads and found both tires worn on the inside... The offside tyre was worse; bald on the inside. The car suspension is standard and i'm guessing the front wheels are cambered? Any other ideas?
Also, how much does it cost on average to get all four re-balanced, and re-cambered?
Ben
If you're running a standard suspension setup then it is likely the tracking is out. Different garages charge different amounts so it's hard to give a figure. But I would look at getting the tracking done first. That's assuming you regularly check the tyre pressures? Wrongly inflated tyres can cause uneven tyre wear.
Sorry new user... I did do a few searches on camber and tire wear, but it just came up with people wanting to know what risks there were for cambering there cars.
Cheers for your help, I get some fresh rubber and get the tracking and probably balancing done just in case.
