hi iv just put a (c20xe dizzy type) into my corsa 1.4 sport, i didnt get a loom with the engine
so i purchased one off ebay everything plugs in perfectly and it fired up straight away was over the moon till i went to put the plug on the tps and relised the engine i have has a 6 pin, but the loom is for a 3 pin tps,
is there any way round this like just changing the tps for a 3 pin one or will i need a new loom again
gutted as i need the car on the road iv been driving a vectra c dti and its pants lol need a bit more power
thanks for looking
fit the 3 pin tps, and its matching ecu
Reactions: bigg1115
thanks
Hi rob thanks for the info i cant get in touch with the lad i got the loom off,
i no my engine is dizzy type c20xe with lambda sensor, the engine i believe is from early astra gsi as it has a sensor under the inlet manifold for traction control,
also my ecu is a gl type
do you no what ecu i should get
thanks again
if your loom is anon trac control one, just get a non trac dissy one. cavgsi iirc.
Reactions: bigg1115
