1 - 7 of 7 Posts
Yeah, a Whiteline one.
I have a front whiteline anti-roll bar and its made a massive difference, far less understeer feels more solid around the corners.
some diesel combos have a 27mm iirc....
I'm also currently looking into this and it would be great for someone to give a review on it as in does it make a great difference?
START QUOTE:
As the name suggests their objective is to reduce sway, or body roll, and stabilise a vehicle under lateral (cornering) forces. Formula 1 cars still use sway bars along side the shocks and springs as it is the ONLY suspension component principally designed to control body roll. Unfortunately, many aftermarket spring manufacturers still design their lowered springs too hard, trying to control body roll when it's the sway bars job.
The fitting of bigger Whiteline Sway bars is still the best dollar for dollar handling improvement you can make.
Why? First, while car manufacturers appreciate the role the sway bar plays in vehicle control, safety and comfort, their standard bars, like the vehicles they are fitted to, are built to a compromise of price, performance and comfort. Secondly, handling and suspension design is an evolutionary process with constant changes.
Whiteline Sway bars dramatically improve the grip, handling and performance of your vehicle. Cornering loads are spread more evenly across the tyres delivering more grip and frankly, that's what it's all about. You also get improved tyre wear as your tyres stay flatter and more upright. Comfort improves because your car sits flatter through bends meaning less movement inside the vehicle.
BARS on CARS - What applies to me and my vehicle?
Whiteline's simple sway bar guide to better handling:
Front Wheel Drive
Increase the rear sway bar size to neutralise understeer.
Rear Wheel Drive
Increase the front sway bar size to neutralise oversteer.
All Wheel Drive
Increase rear then front bar size to fine tune handling behaviour.
4 Wheel Drive
Increase front then rear bar size to neutralise understeer.
Whiteline Sway bars are manufactured using the finest grade Australian spring steel. They are powder coated and supplied with high performance synthetic elastomer mounting bushes in a DIY kit form, ready to simply bolt on.
Whiteline Adjustable Sway Bars
Adjustable sway bars allow their stiffness to be altered by increasing or reducing the length of the lever arms. This permits the roll stiffness to be tuned for different situations without replacing the entire bar. The stiffer the bar, the more force required to move the left and right wheels relative to each other. This increases the amount of force required to make the body roll.
Whiteline adjustable sway bars offer from 2 up to 4 points of adjustment allowing in some cases 10 distinct stiffness settings for precise handling bias adjustment. The Whiteline blade is available across a huge range of applications.
END QUOTE
I use the rear a like you say massive improvement :)
Well I won't bother looking into a stiffer front antiroll bar then. Already got the GSi rear axle with antiroll bar on my 1.0 (needed a replacement and it was mates rates)... Didn't witness much improvement, but at the time I was using crap tires...
Still feels like a boat though lol You can get sea sick in my car! :D
1 - 7 of 7 Posts
