Hi, I have done a conversion to my corsa b fitting a xe engine in buy I have wired up all the connectors I can find things to go to aswell as breather pipes but I cannot find anything more, there's a big plug on the end of the loom which says on most place it goes to the coil? Were does that mean, also the breather off the brake servo pipe, I have two breather pipes, 1 from the fuel rail to the inlet and the other from the fuel yank vent, where does the brake survo one go? Some have said the inlet but there's only two holes for pipes and other have also said the fuel tank vent one dont need to be plugged in? Confused to say the least
Discussion Starter · #2 ·
Also a two pin plus next to the other plug that goes into the sensor that's on the liner pipe the maf or map sensor I believe whete does that go? If pictures are needed please say
As I've said before, most members have moved to
The corsa . Co . Uk
Post some pics up on there, and you will get responses
