Hey,
My drivers side seatbelt is not working the belt itself is fine but the receiver bit that the belt goes into is not letting it click in without a lot of work and jiggling.
How can I fit a new one has anyone had to do this would it mean a whole new seat because of the mechanisms I have looked it up in the Haynes.
if you remove the plastic trim along the edge of the seat (door side) you will see a black tube it has a red pin on the end of it put that in the slot the should be a sticker on it telling you.you may not have to remover the seat but i did it made it easyer.then just remover the one bolt holding the seat belt clip on an remover the cable ties anthe clip an black tube will come off in one an refit new one.its really easy.:thumbs_up:
