Hi all,
I replaced a rear wheel bearing over the weekend, all went smoothly, not a single issue.
Even tightened the handbrake, using the adjuster above the rear axle. (maybe a little to tight), two clicks is the most I get out of the handbrake now.
Anyway, since then, under braking, it feel like there is a judder under my foot. It brakes fine, no one in the car notices anything. It's only a very slight bit of movement under my foot, but when you've driven the same car for 2 years, you notice the very little things that change.
Any ideas what it could be? I was thinking of bleeding the system as it hasn't been done in about a year. Discs? pads? Slaken the handbrake and see if there's a difference?
