1 - 11 of 11 Posts
Bit of a problem with my washer's on the front, the motor is working but no water is coming through to the jets.
Does any one know what size the pipe is so I can order some new pipe?.
And should I order new jets to?
Take the motor out, it may be blocked. It's tight to get in to but just pops off the tank and you'll then be able to see if the filter is blocked.
try just poking a pin in the end of the jets first, they usually block easy.
Quickest way to find out, pull the pipe off the pump, squirt it, if it comes out its not the filter, so push the pipe back on, and disconnect it from the washer jets, if it comes out there, your jets are blocked, if not fault lies between pump and jets.
If no water comes out your pump, then check the filter :)
Ok mate will do this, haven't got a water leak anywhere.
Stupid question but where is the pump located is it on the bottom of the bottle?. So do I need to access it from underneath the car?.
even if it is you wont be able to get to it from underneath, as its right at the top in front of the scuttle
No. It's at the top near the scuttle panel. You can squeeze your hands between the bottle and the wing then grab hold of it and give it a yank.
1 - 11 of 11 Posts
