hi everyone, i have water leaking into the driver's footwell from either the brake servo seal or the steering column seal or both. from my posting i made 12 months back i explained that i had drilled a 12mm hole in the floorpan with a beveled short piece of tubing to allow the water to run out, i also covered all the floor with a 12mm thick plastic matrix to keep the sound insulation and carpets off the wetted area below the plastic matrix. i would post some pictures but for some reason i am not allowed that facility. ?
however although the bodge up works i am not happy with this fix so i asked my local garage would they carry out the major fix, ie: servo out all seals etc, 5 hrs work. they told me they would not do this job as it is a nightmare, £400 ish, but they said that due to the large nuber of corsas have this problem once they are 4 or 5 yrs old, all the seals shrink and fail so a windscreen company in bamber bridge have jigged the job up and turn it around for £250 inc. vat. they guarantee a complete cure. so as the rest of the car is very good this where i think i will be going. mercman.
