On my Saxo, there is a hole in the wheel arch/engine bay which is apparently very common on these.
If I were to weld it, what sort of metal would I need?
Could I use the outer metal case from an old PC tower for example, or would I need something stronger?
Also, would I cut the metal to overlap the hole by about an inch, or would I need it to sit flush inside the hole?
I would like to try doing this myself so trying to find all the help/advice I can as I only have an arc welder and smallest electrodes I have are 1.6mm which seem to work on the PC tower case without too much problem
I will try and upload pictures in a moment if I can.
