1 - 10 of 10 Posts
I am looking to put a c20let into my corsa 1.2 and i was wondering what brakes would be the best ones to put on. i was told astra brakes are really good or will i need afterarket brakes?
Mike
The common option is either the brakes off the Calibra turbo, or the brakes off the v6.
Have a look in my project thread, there's loads of info in there.
You need spiggot rings IIRC and get them re-drilled to 4-stud.
Spigot Rings can be bought from Chris Astley Motorsport for around £15
And, yes, they are needed - the central bore on the Vectra is larger, so without them the discs won't sit centrally :thumbs_up:
i brought my v6 brakes off lmf for £280 thats everything ready to be bolted on! discs already re drilled etc
That including calipers Ant?
I got mine as a second hand fitting kit for £250 including driveshafts etc IIRC.
1 - 10 of 10 Posts
