relinked video at the bottom of this thread
Hi,
I should start with a bit of backstory. The timing chain slipped a tooth and had to be replaced. Which I had done and all seemed fine for about a week. Then this noise is the only way I can describe it appeared. (Watch Vid)
I have since had the coil pack and new sparks to try and remedy as there's no engine management light. Its helped but still louder than it was before I had the chain kit fitted. Also this is intermittent, I can start the car in the morning and it can either be there or not same as I can drive 10 minutes and stop at a junction and it can be there or not.
EDIT: 08 1.4 Design Corsa D
Hi,
