wheel hub nut size
Hello
I went for a EU control and they said I had a bad bearing because the wheel wobbled, I too off the wheel and saw it was a loose disk so I tighten that and all is well, however before I did that I went straight to the hub nut that holds the bearing in place and removed the pin and moved the hub nut with the wrong size socket, before I go buy some odd sizes can anyone tel me the size nut in mm or imperial, I need to get the pin back in as the fingers are covering the hole
95 Corsa B
