OK my alloys have been fitted for a couple of month now, I had them fitted ata garage along with new tyres put on which i took down as well for them.
When they put them on they used new bolts because they couldnt use the steel ones so that was cool plus I took them some locking nuts and they were more than ahpy in doing that.
After driving away i went to test them out but found i had a vibration around 55-60mph. I took the car back the next day and they re balanced the wheels and found them slightly out so sorted them.
Went to drive test again: not really much of a vibration, until i was on a different road. Sometimes they vibrate at 58-60mph and sometimes they are fine until about 70mph.
The garage said I may need spacers cos they will wobble. I said i havent got any but they fitted them anyway, they do not rub therefore I presume spacers are not the solution?
Ive read sometimes you need spigot rings, what do they do and what ones would i need?
Another thing I think it might be is that one of the front wheels is bent ever so slightly, should i swap it for the rear and see what that does?
Any help greatly appreciated thanks
