Hi,
on my Corsa 1.0 litre, when I get to around 50 mph I get a whining noise from the rear of the car. If I take the car out of gear and coast you still get the noise. Any ideas what this may be?
Regards
If it's bearings, which it probably is. Make sure the garage (if not, yourself) do the rear bearings up to the right torque settings on a Corsa B (There's guides on here), mine were over done (to the Corsa C settings) from a garage, I had the rear wheel lock up on me!
Not sure about how specific the Corsa C ones need doing up, but the B needs to be pretty spot on.
P.S. <<<<< might be worth putting what Corsa you drive in your Profile <<<<<
