Hi
I have a bit of a problem with my windscreen washer on a corsa b 2000,
when attempting to use the windscreen washer it wouldnt work but i could hear the motor going, i checked the water level and it was only about 5mm or so from the top so i topped it up again, it worked this time but only until it got to this level again,
the windscreen washer appears to only draw water when it is filled to the brim and as soon as it get to a few mm's off the top it stops but the motor is still heard.
Any reasons for this, will be getting my car mot next month and would like for it be sorted.
I'm not saying this will help but I had the same thing happen to me about 3 weeks ago. I removed the pump and bottle cleaned everything including the filter at the bottom of the bottle to find out that the motor wasn't pushed on to the bottle properly (I don't mean pump pushed down I mean back against the bottle)
It's been fine since
thanks I removed everything and cleaned them especially the small filter in the tank which was clogged with dirt, it now works perfectly, thanks again
