1 - 8 of 8 Posts
Ok i'm planning to change my front door speakers in next week or so. Decided not to get comps - just want a set of 13cm speakers to replace standard ones. I know I will need adaptor rings. What I want to know is how to wire them to original wiring just to run them off headunit as I don't want an amp or anything? Also in pic below which wire is positive and which is negative just for reference?
Existing wiring should be fine, i would of thought the new speakers would just have 2 spade type connectors for the wires to connect to, should be really simple to wire them up. IIRC brown/blue is positive and blue negative.
You cant go wrong really there are only 2 wires :laugh: Should be a five minute job for u geebs.
If you by autoleads adaptor rings You get a adapter which will convert the spade conections into the femal version of the plug you allready have they di when i bought mine 2 motnhs ago from halfords
1 - 8 of 8 Posts
