Hi all,
A bit of a random (and brand new to me!) problem appeared today on my 1.4 Corsa Sport that has left me a tad worried about undertaking some long motorway drives I have coming up.
I gave the Corsa the beans in second up to about 6k/6.5k revs earlier today up toward a junction; when slowing down and stopping at the junction the engine cut out completely. I restarted it and the revs immediately dropped below 1k causing the engine to cut out again. I only managed to pull away from the junction by holding revs on the accelerator and then nursed the Corsa home with it wanting to cut out every time I lifted off of the accelerator regardless of what gear I was in at the time. Throughout all of this the engine temperature was sitting at the normal 93/95 degrees.
It took a good 20 minutes before I could then get the engine to start and idle normally (around 1.1k on my car due to the powerbox manifold and deleted EGR valve; both done around a year ago without issue) without cutting out. It also revs up to 6.5k and settles back to idle without cutting out.
I've ran it around the block a few times and the problem seems to have been cured but the real test will be the drive to work tomorrow in city traffic; I'm hoping it doesn't cut out again!
Does anybody have any idea what may have caused this and what can be done, if it reoccurs, to resolve it permanently?
Cheers,
Cavemark
Cheers,
Cavemark
