XE/LET conversion bits Nova/Corsa/Tigra - Mounts/hubs/shafts/ 3" exhaust/brakes/loom
Alloy FMIC with pipework, joiners and clamps. Not sure if it's complete but looks close enough.
£80
256mm grooved and drilled brake kit (calipers, discs and pads), not seen much use. These are also known as 2.0 brakes.
£60
Big block hubs with bearings pressed into Corsa B / Tigra steering knuckles (as per picture above - everything minus the brakes) - £100
Conversion shafts, I'm told they are Mtec. Fit F16/F18/F20/F28 in Corsa/Nova/Tigra. One CV boot has a slight tear
£100
Slimline fan
£15
Single vee conversion kit. Consists of alternator with brackets, belt, tensioner and pulleys. Everything you need
£50
3" turbo back system. Including TX 3" downpipe and powerflow exhaust. Most of it's 3" with a couple of 2.5" pieces, and 3" tip to backbox
£150
Full set of engine mounts (2x engine, 1x gearbox), still on engine at present but will remove for buyer
£70 for the lot
F16/F18/F20 conversion linkage (pictured above), complete, £50
C20LET engine loom modified for Corsa B / Tigra plug, works perfectly / tested
£100
No offers thanks
£80
£60
£100
Slimline fan
£15
£50
£150
£70 for the lot
£100
No offers thanks
