Anybody know how to set the ignition timing up on a 1.2 16valve chain driven Corsa Sxi? year 1999 Reg V.
I have bottom pulley timing set at Top Dead Centre (TDC) But not 100% sure where or how to set the Cam Positioning Sensor (CPS) at? By this i mean the disc that is on the end of the inlet cam where the cam sensor picks the pulse up from.
I see that there is an arrow machined into the (CPS) but not sure if it has anything to do with the timing or if it does where should it be pointing with the crank set at TDC???
Why did vauxhall do away with distributors?
Any help greatly appriciated guys.
Cheers
Cheers
