Thread moved to https://tinyurl.com/y9lp9qhc
Now THAT is a rather clever design, thanksIt was basically just a self diagnosis test for the display to ensure everything worked correctly. From studying the schematics, I concluded that the original headunit will increase in volume slightly the faster you travelled for things such as traffic announcements, similar to how some satnavs operate.
This was about the corsa b, and thats exactly what i did, cut and insulate, and hide.I take it this is the same for the Corsa B, I have the same problem, head unit is on but then there is no date on the MFD.
So just snip/pull out the red/grey wire and the job is a gooden, even in a Corsa B?
As i suspected then, the reason not to put it back is because im dimmer is broken so i used to get flickering but now it's totally dead. Anyway solved my problem completely by bypasing the dimmer until i can get a new one,i now have 12 volts on both sides of it and has bypased the diming of the dispal as i did not want that fuction anyway. Geting a working dimmer is something that is plans of the future since the car got busted in an accdient today...The illumination wire goes from the dimmer to headunit then the MFD
Why not just put the wire back?
